Activity › Forums › Apple Final Cut Pro Legacy › FCP5 & SONY HVR-M25U
  • FCP5 & SONY HVR-M25U
    Posted by Patrick Redmond on October 12, 2006 at 8:23 pm
    Hi
    I am running FCP 5.0.4, QT 7.1 and 10.4.8 – I bought an HVRM25 HDV deck and can capture just fine, But it will not playback from the timeline in any format, not even DV. Any suggestions will be truly appreciated. Is this a firewire issue or deck set-up ? Any sleepless FCP owners out there to help ?
    Patrick Redmond
    Patrick Redmond replied 19 years, 11 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    October 13, 2006 at 1:26 pm
    If you’re asking about playback and viewing externally… no HDV deck supports this. There are other solutions… AJA, Blackmagic, Matrox, and Convergent design make products less expensive than a capture card for the job…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Patrick Redmond
    October 13, 2006 at 6:41 pm
    Thanks Jerry..it seems that my firewire was non-functioning. i was able to reset the G5 with the SMU button and then manual resets in the Hardware profiler. The problems seems to be a faulty FW drive which was dragging the whole system down. Many thanks for the suggestion.
