Activity Forums Apple Final Cut Pro Legacy fcp5 playback funny
  • fcp5 playback funny
    Posted by James Marshall on July 29, 2005 at 5:09 pm
    I have a dual 2ghz G5 an Aja io setup. Its got plenty of ram (2gb) and 4Tb of disc space but I have an odd problem with it.
    Having just installed FCP 5 and the 5.02 upgrade to get rid of the green line at the bottom of screen. I can now get a clean full screen output on by broadcast monitor but the image in my viewer is a still frame.
    Anyone have a clue as to what setting I may have wrong or is there a new driver I need. I have tried the latest Aja v2.0 drivers but they would not install properly, and so I reverted to my old v1.2 drivers.
    James
    Ryun Hovind replied 20 years, 9 months ago 4 Members · 4 Replies
  • Videobiker
    July 29, 2005 at 5:19 pm
    Check what you have selected for your playback output settings which I believe are under audio/video settings. Make sure you have the correct playback selected for your output type, i.e. compnenet, etc.
    Biker
  • Jerry Hofmann
    July 29, 2005 at 5:39 pm
    I think you need that 2.0 update Running FCP 5…
    Jerry
  • James Marshall
    July 29, 2005 at 7:19 pm
    Thanks for the thoughts.
    I tried trashing my preferences, and lo and behold it worked properly. I should have tried this before posting.
    Cheers
    James
  • Ryun Hovind
    December 13, 2005 at 11:52 pm
    HEY James,
    What preferences did you trash and where might they be? I am having the same problem!
    RH
