Activity › Forums › Apple Final Cut Pro Legacy › FCP5 multichannel audio capture
Posted by Orwa Nyrabia on January 22, 2006 at 9:03 amWe are working on a DP G5, OSX 10.3.9, Declink Extreme with software v. 4.8.1
Is it impossible to capture more than 2 channels of audio with these settings?What are the requirements to capture 4 channels?
We are still worried about upgrading to Tiger with all the troubles we are reading about!
Orwa
Orwa Nyrabia replied 20 years, 8 months ago 3 Members · 7 Replies -
David Roth weiss
January 22, 2006 at 9:29 am1. To capture four channels of audio simultanously you would have to capture via SDI. Are you? There are only two analog audio inputs.
2. Problems with Tiger??? What exactly would those be?
DRW
Orwa Nyrabia
January 22, 2006 at 9:36 amDavid,
thank you first.
We are capturing via SDI. but the audio capture settings are only offering: first two channels or 3+4 channels.
We have Tiger… but have not installed it as we are on a rolling work period. many users reported QT problems and incompatibility issues… would you recommend upgrading while working on unfinished projects?
Would we also have to upgrade Tiger after installing it in order to gurantee a good workflow?But anyway, shouldnt we be able to capture the 4 channels (at least) with our current system?
Orwa
David Roth weiss
January 22, 2006 at 3:54 pmOrwa,
Yes, you should be able to capture (at least) four channels of audio. I’ll get back you later today after I have a look at the settings on my system.
As for upgrading to Tiger, consider a complete reinstallation on a new drive, and keep your present system drive as a backup until you are absolutely certain that everything is working well. Its a very simple way to upgrade without any pressure or concern about losing anything.
DRW
David Slater
January 22, 2006 at 4:41 pmif you are using QT 6 you can only capture 2 channels
if you are using QT 7 you can capture 24 channels IF you have a compatible capture deviceDAVE at Movies Rock in Toronto
David Roth weiss
January 22, 2006 at 6:06 pmThanks Dave. You saved me some searching. That must be Orwa’s problem.
Orwa Nyrabia
January 23, 2006 at 1:11 pmThank you very much guys…
I recieved the following from BMD’s support team:
<< Hi Orwa, You should be using OS 10.4 with our v5.x driver and Final Cut Pro 5 for multiple audio channel capture. We do not support 10.3.9 as this configuration has been reported to be problematic by man of our customers. Regards >>
But will try QT7 first as it is compatible with 10.3.9 as apple.com says!
Orwa Nyrabia
January 23, 2006 at 1:13 pmThank you very much guys…
