Activity › Forums › Apple Final Cut Pro Legacy › FCP5 exporting the last ounce of quality
  • FCP5 exporting the last ounce of quality
    Posted by Dennis Couzin on October 14, 2007 at 5:22 am
    I’ve been thrown at a FCP5 job without opportunity to learn. The 80 minute DV25 project will be exported to QuickTime. The .mov will then be converted to DigiBeta. Whatever way the project was shot, it now contains subtitles, color effects and motion effects from FCP5. Now, I don’t care how huge the .mov is out if this can add one ounce to the quality. Does how I render affect the quality of the QuickTime export? For example, if I render as DV PAL, but then make the QuickTime as Uncompressed 10 bit, are the results different from using Uncompressed 10 bit at both stages?
    Richard Harrington replied 18 years, 11 months ago 2 Members · 1 Reply
  • Richard Harrington
    October 15, 2007 at 12:40 am
    Do not render to DV unless you shot DV
    Set your sequence to match the compression of your intended output device
