Activity Forums Apple Final Cut Pro Legacy FCP5 / DSP4 Output To TV
  • FCP5 / DSP4 Output To TV
    Posted by Alex Maldonado on June 19, 2005 at 5:17 am
    if i want to use the second monitor slot on my ATI Radeon 9600 XT 128 to view my FCP monitor on a TV what adapter deally bopper will i need to get. and will it also work with DSP4 as well?
    thank you all.
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 20, 2005 at 2:31 pm
    DV? You need an ADVC-110 for it… (canopus.com) or you can use a DV deck or camera and send the video out to it, and take the analog outputs of the machine/camera to a video monitor.
    Other than DV? You probably already own what you need… i.e. a Kona Card or other capture card.
    DVD SP doesn’t support external video don’t think.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
