Activity › Forums › Apple Final Cut Pro Legacy › FCP5 Decklink HD & Monitoring
Posted by Chip Whiting on May 31, 2005 at 6:15 pmI have the decklink HD card installed, now my question is, my monitor doesn’t have an SDI in, only component, hdmi & s video. How do I hook it up to my monitor?
Chip Whiting
99 Productions LLC
541-343-0099Michael Gissing replied 21 years, 3 months ago 4 Members · 5 Replies -
Walter Biscardi
May 31, 2005 at 6:38 pmThere are several SDI – Component conveters out there. BlackMagic and AJA both have very good ones.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Chip Whiting
May 31, 2005 at 10:28 pmSo not only did I have to buy this Decklink HD, but now I have to buy another piece of hardware to see video on my HD monitor? Is there another way to see HDV on my main monitor, now that it doesn’t go through firewire?
Chip Whiting
99 Productions LLC
541-343-0099 -
Walter Biscardi
May 31, 2005 at 11:07 pm[chip] ”
So not only did I have to buy this Decklink HD, but now I have to buy another piece of hardware to see video on my HD monitor?”Did you not research the Decklink HD and see that SDI output was the only output on it? You could have purchased the Kona 2 and used either Component or Composite video outputs which are included. That’s what I use.
[chip] “Is there another way to see HDV on my main monitor, now that it doesn’t go through firewire?”
Through your camera?
Matthew Small
May 31, 2005 at 11:12 pmIf you needed component outputs from the card, you should have purchased the DeckLink HD Pro
Michael Gissing
May 31, 2005 at 11:13 pmThe Decklink HD Pro has both SDI and component output which I use to input my Sharp 45″ Aquous HD monitor. Works a treat for both HD and SD. I would use this instead of the Decklink HD and a component converter.
