Activity › Forums › Apple Final Cut Pro Legacy › FCP5 audio waveform failure
  • Walter Biscardi
    June 21, 2005 at 11:57 am
    Is there actual audio on that track? Meaning, you can solo Track 1 and you hear audio?
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Chris Poisson
    June 21, 2005 at 1:05 pm
    Hey Walter,
    Yes, there is audio on it, if I drag the tracks to 3 and 4 I can see the waveform in both. It just seems weird that track one is invisible. Weirder still, this happened mid-edit, yesterday morning I could see it and later in the day it went away. Everything else about the project seems fine.
  • Walter Biscardi
    June 21, 2005 at 1:38 pm
    I wonder if the project is corrupted somehow.
    You could try creating a New Project with a New Sequence. Then go into your original Sequence, Copy All, then Paste everything into the New Sequence. If the audio waveforms show up there, then your original project has gotten corrupted somehow. You can literally drag everything from the old project over to the new one and just give it a revised name.
  • Chris Poisson
    June 21, 2005 at 3:27 pm
    Hey Walter,
    Ya know, this is EXACTLY what I was thinking on my run this morning, and I was wondering about how to do it. Thanks a bunch!
  • Walter Biscardi
    June 21, 2005 at 8:17 pm
    Hope it worked!
  • Ken Pugh
    June 21, 2005 at 10:40 pm
    Another thought – I once had a similar problem, it turned out the hard drive containing my waveform scratch files was full – had gillions of files in there from past projects. Deleted them and designated a larger disc, problem solved.
    Ken.
  • Chris Poisson
    June 22, 2005 at 12:22 am
    Walt,
    Worked awesome, and we finished the rough cut of a 15 minute show just before the client got here, and just two nitpick changes!
    Ken,
    Good thought, but my drives have loads of space left.
