Activity Forums Apple Final Cut Pro Legacy FCP5 Audio Capture Problem
  • FCP5 Audio Capture Problem
    Posted by Chris Babbitt on June 20, 2005 at 9:41 pm
    I set up a separate audio capture preset, just as I have in past versions of FCP for capturing just audio from a digital MD recorder. In the Capture Window, I have Device Control set to Non-controllable Device, and I’m using Capture Now. As soon as I stop the capture, I get a message that says “FCP is unable to read the file just created,” and, sure enough, if I open that file in Quicktime, it does not recognize it as a legitimate file. My capture setting matches that of my audio recorder…44.1 khz. What am I doing wrong? This has worked for me since version 1. Fortunately, I kept FCP 4.5 on the system, so I’m going back to that to capture my audio until I figure this out.
    Chris Babbitt replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
