Activity Forums Apple Final Cut Pro Legacy FCP5 and exporting MPEG2
  • FCP5 and exporting MPEG2
    Posted by Klaus on July 7, 2005 at 11:32 pm
    Having recently installed FCP 5 as part of Production Studio, I have found that when I attempt to export as a Quicktime Conversion, the option of exporting as MPEG2 does not appear. According to the manual, if you have installed Compressor or DVD Studio Pro you should be able to export as MPEG2. Any idea how to re-enable this function?
    Klaus replied 21 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Babbitt
    July 8, 2005 at 2:51 am
    I don’t have it either, eventhough it is listed in the Quicktime folder inside the Systems folder.
  • Walter Biscardi
    July 8, 2005 at 4:31 am
    Not here either. Hopefully this will be fixed with the first update to FCP.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Scot Walker
    July 8, 2005 at 6:38 pm
    If you “Export Using Compressor”, you will then have all kinds of presets for MPEG2 in Compressor. I think you can just drag and drop FCP project files into Comrpessor too, if you want, if you don’t have FCP loaded and you want to encode a project from the Finder.
  • Chris Babbitt
    July 8, 2005 at 6:53 pm
    I spoke to Apple Support this morning, and apparently, they purposely left out MPEG2 from the export options with FCP5, because they claim it did not work well. Too bad, because I used it to help me estimate the bit-rate for a project before I encoded with Compressor.
  • Klaus
    July 10, 2005 at 12:14 pm
    Thank you all for your responses. I’m exporting using Compressor and it seems to be working ok.
  • Klaus
    July 11, 2005 at 2:43 am
    Further to this: exporting using Compressor works OK but seems to take about twice the length of time. Does anyone else find this? Any idea why?
  • Klaus
    July 11, 2005 at 2:45 am
    Sorry. Just noticed another thread on this topic. Obviously pays to read them before posting.
