Activity Forums Apple Final Cut Pro Legacy FCP3wont render Error Type2 and 3
  • FCP3wont render Error Type2 and 3
    Posted by Sid Coleman on February 3, 2008 at 9:45 am
    Feb08 FCP Troubles:
    Using a G-4, at 733 Mhz, with 768 mb SDRAM, on MAC OS 9.2, FCP3.0.4,
    QT 6.0.3, Carbon Lib 1.6
    WIll not render 5 minutes of video with about 10 gig worth of renders in it.
    So,I saved the FCP project twice with 2 different names then tried to re-open my project. A pop-up box appears and says “Codec not found”. Type 2 error
    Then I got out of that and trashed Preferences and MOA cache. Both of which, after I finally found, where not in their normal place. They used to be under FCP prefs. Now they are in Custom Settings under Final Cut Pro User Data and are the only things there in that file.
    Now when I fire up my project, I get “Type-3 Error” pop-up.
    I hope some bright young person can help me. I am already a week late getting this one out because of some missing codec in FCP-3.
    PS- Am not hooked up to the Internet with this G-4 with the project on it.
    I do have my 1997 Toshiba on line. It’s a PC and doing temporary duty until I get
    my slightly better PC fixed and back together.Please email me.
    Sid
    Zane Barker replied 18 years, 7 months ago 2 Members · 5 Replies
  • Zane Barker
    February 3, 2008 at 11:28 pm
    [Sid Coleman] “Using a G-4, at 733 Mhz, with 768 mb SDRAM, on MAC OS 9.2, FCP3.0.4”
    [Sid Coleman] “I hope some bright young person can help me.”
    No offense but not many young people are going have much experience on a machine that old and especially with an OS and version of FCP that old.
    [Sid Coleman] “A pop-up box appears and says “Codec not found”. Type 2 error “
    If some codecs are missing try and reinstall your FCP.
    Don’t let technology get in the way of your creativity!
  • Sid Coleman
    February 4, 2008 at 5:10 am
    Thanks Zane, but a re-install is not an option, not only because of time, but because all runs fine with other files/projects, that aren’t loaded with jpgs, nor lots of rendering like this one.
    Sid
  • Zane Barker
    February 4, 2008 at 5:15 am
    [Sid Coleman] “but because all runs fine with other files/projects, that aren’t loaded with jpgs, nor lots of rendering like this one. “
    jpegs and having lots of rendering have ABSOLUTELY NOTHING to do with codecs like the error message says. Besides a reinstall of the application douse not take that much time to do.
    You should still try a reinstall.
  • Sid Coleman
    February 6, 2008 at 8:26 am
    FCP-3 Using a G-4, at 733 Mhz, with 768 mb SDRAM, on MAC OS 9.2, FCP3.0.4,
    The reason I was interested in keeping my FCP-3 on OS-9 running, is because
    in it somewhere is the proper firewire protocol for my Panasonic DMR ES15 DVD recorder. I was able to get great (fairly uncompressed) video directly onto a DVD in real time. The only rendering was for the graphics, composites and tweeked clips (within the FCP timeline). Because of too many renders in my last project, FCP3 in OS-9… crashed with Errors Type 2 and 3. The project would not open again.
    So, I took Zane’s advice from Creative Cow and loaded FCP-3 into my OSX.2.8 and now FCP-3 won’t work in OS-9 anymore, because it needs OSX-1.1 which now has been changed to OS 10.2.8. OS 10-1.1 is gone.
    The project was retrieved in OS 10, but no output with firewire to anything but the camera (Sony PD-150). That works, but is hard on the Camera.
    That magic firewire protocal extension is not there anymore either. I am guessing the thing to do is to find the Panasonic protocol for firewire that works with the DMR ES15 DVD recorder and OSX 2.8.
    Does anyone know where/how I can find one? Am I on the right track?
    I really don’t like the noisy artifacts that appear in the video with burning. All the above is the same when using FCP-4 on OSX-3.1) on my other computer too.
    I need firewire protocol that talks to the DMR ES15 from OS 10.2.8.
    I should post this as a new problem.
    Sid
  • Zane Barker
    February 6, 2008 at 8:41 am
    [Sid Coleman] “I took Zane’s advice from Creative Cow and loaded FCP-3 into my OSX.2.8 and now FCP-3 won’t work in OS-9 anymore”
    I NEVER recommended reinstalling FCP in OS X I recommended reinstalling it in OS 9. You NEVER even mention you had a version of OS X running on the machine.
    I am sorry for you but your setup is so OLD that I really don’t think that you will be able to find much help on the issues you are having. I used OS 9 just a hand full of times and hated it, it want until OS X came out that I fell in love with the mac.
