Activity Forums Apple Final Cut Pro Legacy FCP3 to tape on G4
  • FCP3 to tape on G4
    Posted by Glennv on October 3, 2005 at 5:29 pm
    Using my Canon as a tape deck, I am trying to record from my timeline to DV but not picking up anything on tape. Set up as follows: Firewire direct to computer (will log and capture from a test tape), external video on, set to output video (DV-NTSC), Canon set to vcr mode, timeline clean-no in out points, hit record, timeline puts out on monitor and nothing on the DV! Restarted computer-just in case. Any ideas? Done it in the past, no problem. Missed something?
    Glennv replied 20 years, 11 months ago 2 Members · 2 Replies
  • Rob Forsythe
    October 3, 2005 at 9:05 pm
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    If working this list doesn’t cure the problem… you may have a PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    14. Important: Quit FCP, then Restart FCP.
    15. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
  • Glennv
    October 4, 2005 at 2:26 pm
    Thanks. Now it is working. I did as you suggested as well as re-installed FCP3 (which probably reset my preferences) and rebooted and it showed up on the camera LCD and Bingo! I find I have to re-install FCP periodically when gremlins like this crop up. Again, many thanks. Great response! Now to get my FCP5 installed.
