Activity Forums Apple Final Cut Pro Fcp11 only exporting apple prores
  • Fcp11 only exporting apple prores
    Posted by Carlo Ferraro on November 24, 2024 at 3:03 am
    After installing the version 11, it does not export but appleprores, any of them, it is also happening in the compressor, so I guess it is a setting. My files are from Sony cameras, 4K25 to 4K100, no picture profile, color 709.
    Tried any of the dozen others I usually use.
    Devrim Akteke replied 1 year, 9 months ago 4 Members · 6 Replies
  • Devrim Akteke
    November 24, 2024 at 4:46 am
    It is a bit strange as I can continue exporting the same before I update. Everything seems the same.
    When you choose File>Share>Export File, the same old options appear. I can still use my previous Compressor setups. I cannot figure out why, but maybe you can try reinstalling and using Disk Utility to check the system.
  • Frank Valtellina
    November 24, 2024 at 8:08 am
    Prova a reinstallare i “Pro video formats” 😉
  • Carlo Ferraro
    November 24, 2024 at 9:00 am
    Thanks Devrim.
    I’ve been using FC since I moved to Mac in 2007 and this was the first time this ever happened. After using common sense of 50 years in the biz, trying everything, I remembered that I did not restarted the computer (never did with previous updates), so I decided todo it. Guess what? It worked.
    As I say (from my previous life being a Chemistry Professor), the Free Electrones around the outer orbits of the transition elements doing their thing!
  • Devrim Akteke
    November 25, 2024 at 6:06 am
    It is always best, a good old restart😛
  • Eric Santiago
    November 27, 2024 at 1:59 pm
    I haven’t jumped the gun yet with this update, but do you still have to download the Pro package codecs from Apple?
  • Devrim Akteke
    November 27, 2024 at 4:32 pm
    No Pro video codecs update is not only about FCPX. It is mostly a support at Mac Os level. You can update it and you don’t have to update FCP. Your old FCP version will work without problems if you update it or not.
