Activity Forums Media 100 FCP XML to Media 100 1.1.1
  • FCP XML to Media 100 1.1.1
    Posted by Ben Masterson on December 10, 2009 at 9:18 pm
    I was wondering if there was something special you had to do to get an XML of a timeline from Final Cut Pro v 7.0 to Media 100 Suite 1.1.1. I think I have tried every XML version Final Cut does…but Media 100 says it is not a recognizable XML file. With the error invalid xmlChar value 8 in the Log window. This timeline was originally xported as an XML from Media100 to Final Cut.
    Is there anything special I have to do? I haven’t found anything online yet
    -Ben
    Matt Mullen replied 16 years, 9 months ago 2 Members · 3 Replies
  • Matt Mullen
    December 10, 2009 at 9:32 pm
    Ben,
    How are you creating the XML in FCP?
    It sounds like there might be something in the XML that M100 doesn’t understand.
    Can you send the XML to support@media100.com attn:Matt. I will try to take a look and see.
    As a test create a new project in Final cut, just toss in some color bars, export an XML and see if that works just to make sure.
    -Matt
  • Ben Masterson
    December 10, 2009 at 10:22 pm
    Ok I tried it with another program and it worked. Upon further inspection, FCP is seeing my timeline media as “offline” even though it is playing fine. I had originally exported this timeline from Media 100 as xml and imported it into FCP, I guess that is where the screw up happened.
  • Matt Mullen
    December 11, 2009 at 4:48 pm
    If you want send me the original XML and the most recent XML and I can take a look at it.
