FCP XML Import not working with Sony 120fps camera files
Hi all,
I’ve usually had no issues with importing FCP X XML’s into Davinci projects. In fact normally I just edit in Davinci, but I decided to edit in FCP X with Sony A7 III footage. The Sony files are UHD 120fps Slow motion files, that read as 23.98fps footage, which I assume the camera took care of. The files are not in a FCP X library but in it’s own directory.
When I import the FCP X XML it gives me an error saying that it can’t find the footage. It then gives me the option to look for the footage but when i direct it to the directory, it still errors, saying it still can’t find the footage. When I choose the “No” option, when importing media, it then gives me the following error: No overlap between specified target timecodes and located file timecodes
It then imports what looks like a bunch of audio clips with the name of the video clips. This is really odd, and I’ve never seen this before. This is also my first time shooting with the Sony camera, so I’m wondering if it’s related, to how I imported the Sony media? Anyway…would love some guidance if you have any. Thanks!!
It’s also worth noting when importing the same XML in Premiere Pro, I don’t run into this issue at all……
