Activity Forums Adobe Premiere Pro FCP xml import fail
  • FCP xml import fail
    Posted by Heather Brown on February 3, 2013 at 6:33 pm
    I get this message when importing an FCP 7 xml into PP CS6.
    Sorry, a serious error has occurred that requires Adobe Premiere Pro to shut down. We will attempt to save your current project.
    I tried an xml that only have 1 small rendered DVCPRO HD clip & it worked fine – so the workflow is working.. It just crashes when I import a project that has graphics & such – even when rendered. Also DVCPRO HD footage. 720. Any idea what the problem could be?
    Heather
    Heather Brown replied 13 years, 7 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    February 3, 2013 at 7:37 pm
    What version of XML is it? Also you might want to try and clear your preferences.
  • Heather Brown
    February 3, 2013 at 7:42 pm
    Hi Tero. Thank you for your reply. Apple XML Interchangeable format, version 5. From FCP 7 into Premiere Pro CS6. Which preferences should I clear. I’m new to PrPro.
    Heather
