Activity › Forums › DaVinci Resolve › FCP XML based on mov .. will it relink to r3d ?
  • FCP XML based on mov .. will it relink to r3d ?
    Posted by Sascha Haber on July 6, 2011 at 8:26 am
    Hi there,
    ok, I admit this is the n00b post, but does anyone know what I have to tell the editor to deliver a working XML when they are editing from proxy files, but intent to do the grading from truncated r3d clips ?
    I have all the clips, and the edl they generated works fine.
    I just cant seem to make the XML work, but its probably me doing it wrong..
    Any kick start would be well appreciated 🙂
    2522_aliveallesv4.xml.zip
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    MacPro 5.1 2x 2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
    Dan Moran replied 15 years, 2 months ago 2 Members · 1 Reply
  • Dan Moran
    July 6, 2011 at 10:47 am
    Hi Sascha,
    Have you tried using the Assist using reel numbers from the source clip file path name option ?
    If you try that, add to the media pool as normal and then turn off auto import on the XML it works everytime for me.
    Hope this helps!
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
