Activity Forums Apple Final Cut Pro FCP X won’t import wav file
  • FCP X won’t import wav file
    Posted by Michael Kienitz on July 20, 2012 at 12:50 pm
    I have a translation track on a wav file which I previously imported into FCP X and then removed. For
    some unknown reason to me it will not allow me to reimport it. I’ve tried both drag and drop and using
    the “import” menu method. I do not receive any error messages but it does not show up in the events.
    Could the problem be that it was previously imported and then deleted? The file is not corrupted and plays
    in Audition just fine. I guess I will try trashing prefs. It did import fine previously but I deleted it but have now decided to use this track instead of another. Other files import fine, I’ve renamed the file and tried importing it but that made no difference as well as changed it’s location prior to importing. Any ideas or suggestions would be greatly appreciated.
    http://www.michaelkienitz.com
    5108 Tomahawk Trail
    Madison, WI
    Michael Kienitz replied 14 years, 2 months ago 3 Members · 5 Replies
  • Andy Neil
    July 20, 2012 at 4:05 pm
    A lot of times, people select a clip and hit delete and they think that they’ve deleted the clip from their event. In reality, you’ve only labeled the clip as “rejected” and it’s still in the event. It won’t show up because the default browser view is to hide rejected clips.
    I suggest clicking on the browser view drop down and choosing All Clips (CTRL+C) and then see if you see it. If you do then select the clip and hit U on the keyboard to remove the rejected status from it and you can return to Hide Rejected view (CTRL+H)
    This would explain why you don’t get an error message when you try to import because FCPX recognizes that you already have the clip in your project.
    Andy
    https://www.timesavertutorials.com
  • Michael Kienitz
    July 20, 2012 at 4:30 pm
    Solution was to create a new “event” then drag the problematic file to the previous “event” I was working with. Of course I could have also left it in the new “event” but I chose not to.
    5108 Tomahawk Trail
    Madison, WI
  • Michael Kienitz
    July 20, 2012 at 4:32 pm
    Thanks very much Andy, it was indeed no longer there…deleted not rejected but I appreciate the information you’ve given me for future projects.
    5108 Tomahawk Trail
    Madison, WI
  • Jacob Lanum
    July 20, 2012 at 5:55 pm
    I had the same thing happen towards the end of my last project. Not only could I not reimport a clip I deleted but any new media wouldnt show up as well. A new event solved the problem but it makes me nervous about the stability of FCP X
  • Michael Kienitz
    July 21, 2012 at 9:01 pm
    Amen, pretty surprising something as basic as that has not been attended to.
    5108 Tomahawk Trail
    Madison, WI
