Activity › Forums › Avid Media Composer › FCP X to Avid Media Composer without creating new media
  • FCP X to Avid Media Composer without creating new media
    Posted by Melissa Warren on May 22, 2018 at 3:01 pm
    Hi
    I have been away from my edit desk for a few years and am now returning to the profession. The first job I have is working with an existing sequence that was previously cut in FCP X. I am an Avid fan and really don’t want to have to work in FCP so am trying to get the sequence into Avid MC. I have worked out how to do this using an FCPxml into Resolve and then exporting an AAF file. However it involves re-creating all of the sequence media when actually I have the original media and don’t want to create new media.
    I’ve managed to get the sequence into Avid by exporting an AAF from Resolve (without transcoding the media with the export). I can see the sequence but obviously it’s all offline. So I thought I my be able to relink it using AMA to the original (I can see all the clip names in the sequence and they correspond to the original media on my drive) so each time the sequence is moved between Avid and FCP its referencing the same media. However I cannot get Avid to relink to the original media. Does anyone know if this is possible?
    Thanks so much. Mel
    Melissa Warren replied 8 years, 3 months ago 3 Members · 4 Replies
  • Shane Ross
    May 22, 2018 at 5:34 pm
    [Melissa Warren] ” However it involves re-creating all of the sequence media when actually I have the original media and don’t want to create new media. “
    Sorry, but that’s what you’ll need to do if you want to do this. You can TRY to AMA link the footage in Avid and then link that to the sequence you bring from Resolve, but I haven’t heard many people have success with that.
    [Melissa Warren] “However I cannot get Avid to relink to the original media. Does anyone know if this is possible? “
    I’m not sure what happens to the metadata, but when I tried this myself, I got maybe 1/4 of the clips to relink…and with maximum effort. But when I transcoded, it was fine. Avid really prefers transcoded media anyway, so doing that would be fine.
    Shane
    Little Frog Post
  • Phil Vo
    June 17, 2018 at 5:03 pm
    I’m actually dealing with a similar scenario.
    Shane, are you stating that I should transcode the offline sequence in Avid for my media to be back online?
    Melissa, any luck relinking all your offline media? Any other methods you may have attempt to get your media back online?
  • Melissa Warren
    June 26, 2018 at 9:35 am
    Hi
    Apologies for tardy reply- these emails weren’t going into my trash but my spam folder- which I can’t seem to access unless I search for specific messages. Anyway I did have some luck but not enough for me to think this is a viable solution long term.
    The thought of having to transcode each time we want to move a sequence between the two systems made me recoil in horror as I just think it’s a recipe for disaster. If it’s only being done once then fine, but we were looking for a solution to allow for us to freely move between systems numerous times. This is what avid told me to do:
    To export from FCPX to Avid you have to use DaVinci Resolve (which you can get free of charge from BlackMagic’s website). This seems to be the best workflow for going from FCPX to Avid.
    https://www.blackmagicdesign.com/products/davinciresolve/
    – In Final Cut Pro X go to File > Export XML where you will be asked to name and save a new .fcpxml file format. The new .fcpxml file can be imported into Resolve.
    – In Resolve click Load and select your FCPXML file.
    – A dialogue box will pop up, click Ok.
    – You will now be able to see your clips in the timeline.
    – Inside of Resolve go to Session and Click Render.
    – Under the Easy Setup tab select Avid AAF Round Trip.
    – After selecting your desired export codec you can simply hit render. Your clips will now render.
    – Once completed you can jump into Avid and import the AAF file which will pop up as a single sequence.
    – If you have multiple timelines you will need to export multiple AAF files. The clips should automatically pop up in Avid. It’s a long process but it works.
    It did work but like I said this isn’t suitable for moving between systems multiple times.
    I did have more luck than I thought I would by exporting the sequence from FCP, bringing it into Avid (without any media being transcoded) and following the instructions on this video: https://www.youtube.com/watch?v=CZWnnCpFDds but using Davinci Resolve instead of Automatic Duck.
    It did take me a good few times and playing with the setting to get media to relink but eventually about 70% of it did.
    I’ve had to swallow my preferences and finish this project on FCP but next time I’m insisting that we just work in Avid!! Hope this helps!
  • Melissa Warren
    June 26, 2018 at 9:36 am
    Shane- sorry for not replying to your response sooner and saying thanks. M
