Activity Forums Apple Final Cut Pro FCP X Title: BG The TAB Stops Here
  • FCP X Title: BG The TAB Stops Here
    Posted by Brendan Gibbons on August 18, 2011 at 5:01 pm
    BG: Titles in FCP X
    “BG The Tab Stops Here”
    This is an FCP X Title preset. This preset is designed to give you better layout control of text on screen.
    The Text box is the size of the HD safe title area in FCP X.
    FCP X Title: BG The Tab Stops Here
    There are Tab Stop controls in place to enable
    you to arrange your text as well.
    You can easily align your text left, right or centre of screen. Something which is a bit annoying to do with the default text controls in FCP X.
    – Additional global scale controls
    – Offset controls to globally reposition text
    – Global Character Rotation
    – Monospace Option
    – All Caps option, with all Caps size control
    Screenshots:
    Inspector Controls:
    Drop the folder inside this zip called BG The Tab Stops Here into the following directory:
    Movies / Motion Templates / Titles / BG Titles /
    Cheers,
    BG
    Brendan Gibbons replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
