Activity › Forums › Apple Final Cut Pro Legacy › FCP X The document “CurrentVersion.fcpevent” could not be opened.
  • FCP X The document “CurrentVersion.fcpevent” could not be opened.
    Posted by Peter Fraser on April 30, 2013 at 1:37 pm
    I’m using the trial FCP X. I saved a CurrentVersion.fcpevent on another mac with another trial copy. I’m trying to open it on a second mac from an external HD but I just get ‘The document “CurrentVersion.fcpevent” could not be opened’ and a command to open it in FCP X. I can’t see how to open it in FCP X. When I move the files to the internal HD it doesn’t make a difference. When FCP X opens it doesn’t find them and just creates a new event.
    The files I’m trying to open are: CurrentVersion.fcpevent and CurrentVersion.fcpproject. Can anyone help? I’m at the the Toronto doc fest and I need to access the files!
    Thanks 🙂
    Peter Fraser replied 13 years, 5 months ago 2 Members · 2 Replies
  • Neil Patience
    April 30, 2013 at 2:47 pm
    Hi Peter
    You should re-post your question in the FCPX Techniques forum. This is FCP Legacy and while someone might know the answer much more likely
    here
    https://forums.creativecow.net/fcpxtechnique
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
  • Peter Fraser
    April 30, 2013 at 2:57 pm
    Thanks Neil
