Activity › Forums › Apple Final Cut Pro › FCP X support added to Movie*Slate app
Robin S. kurz replied 10 years, 3 months ago 6 Members · 14 Replies
Robin S. kurz
May 24, 2016 at 4:46 pmJust for prosperity, since I just happened upon this thread (very) late: I use and LOVE this app. Connecting the Movie★Slate log to clips is a cinch. You simply put all the clips and the XML into one folder and import the XML into FCPX. Done. Tagged, keyworded, noted etc. etc. Literally saves me DAYS of work. Highly recommended.
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Robin S. kurz
June 2, 2016 at 5:36 pmBTW, since I just now have the case of NON-QT footage (mxf), I would add that the workflow merely involves also using “Shot Notes X”. You first import (i.e. wrap) all the footage into FCP X (in my case) via archives, then generate an event XML, take that and the MS XML and import them into “Shot Note X” (as of late it ‘understands’ Movie Slate XML) and then generate a third XML with all the needed info that, again, you simply double-click and get any and all keywords, favorites, markers, ratings, notes etc. etc. etc. etc that you entered on set for each clip. If you also have the “Sound Dept.” plugin for Movie Slate, then you even get your clips with synced audio. That saves you minimum yet another day of work.
Metadata FTW. I’m blown away by the entire workflow.
– RK
Darren Roark
June 2, 2016 at 7:12 pm[Robin S. Kurz] “If you also have the “Sound Dept.” plugin for Movie Slate, then you even get your clips with synced audio. That saves you minimum yet another day of work.”
Does it apply the mic track iXML labels like Sync N Link?
Robin S. kurz
June 3, 2016 at 7:14 amSee here: https://www.movie-slate.com/sound_dept/ 😉
– RK
