Activity Forums Apple Final Cut Pro FCP X Roles – Will only export mono, not stereo or surround.
  • FCP X Roles – Will only export mono, not stereo or surround.
    Posted by Ben Whitehead on January 5, 2012 at 8:38 pm
    I am attempting to export my audio to be mixed in a different program. I have found that when I attempt to export the audio via the roles feature it does not export roles as either stereo or surround. It attempts to, then gets to 97% and stays there. I changed the roles to export as Mono and they worked, however this useless as it is music.
    I have simply no idea at all why this doesn’t work, has anyone else experienced this, and have a workaround, or any form of explanation?
    As an aside I also can’t export audio on its own. Final Cut will try, open up the monitor thing, attempt an export and then fail.
    T. Payton replied 14 years, 8 months ago 2 Members · 1 Reply
  • T. Payton
    January 6, 2012 at 3:49 am
    Haven’t had this problem. Sounds like you might have a corrupted audio file in there somewhere. I would try to isolate it by disabling clips with “v”.
