Activity Forums Creative Community Conversations FCP X Render Problem
  • Bret Williams
    May 11, 2012 at 4:40 pm
    Did it play, or just have the orange marker above it? I’ve found a few times that the orange doesn’t go away, even if fully rendered. For example, I can select all, and press ctrl+r and nothing happens. There’s no render to occur.
  • Ricky Dominguez
    May 11, 2012 at 4:56 pm
    Thanks Bret for the replay, no the orange parts wasn’t render so I have to re-render.
    Ricky
  • Oliver Peters
    May 11, 2012 at 6:33 pm
    When this happens, delete the project’s render files and re-render. Should be OK after that.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
