Activity Forums Apple Final Cut Pro FCP X Project (timeline) to FCP 7
  • FCP X Project (timeline) to FCP 7
    Posted by Adam Berch on April 12, 2016 at 3:00 pm
    Is there a way to exporter a FCP X timeline or Project to FCP 7 without using X27?
    Thanks in advance.
    FCP X 10.2.2
    FCP 7
    Doug Metz
    replied 10 years, 5 months ago
    4 Members · 4 Replies
  • Jeff Kirkland
    April 12, 2016 at 8:23 pm
    Resolve might do it via XML but Xto7 is your best bet. It’s been a long while since I used Xto7, or XtoCC as it is now but keep in mind that any trip back to FCP 7 is going to be a dumbed down version of the project because 7 ain’t that smart.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Adam Berch
    April 12, 2016 at 8:43 pm
    Thanks for the info. Here is what I am trying to do.
    I have a 20 minute timeline in FCP 7, I exported it as an XML from FCP 7. I used 7toX and brought it into FCP X. I want to be able to do a color correction in FCP X, export it through XML back into FCP 7 where all of the color changes are still present that I did in FCP X.
    How can I accomplish this? Please give me step by step instructions.
    Thank You in advance.
  • Oliver Peters
    April 12, 2016 at 9:00 pm
    [Adam Berch] ” I want to be able to do a color correction in FCP X, export it through XML back into FCP 7 where all of the color changes are still present that I did in FCP X. “
    Not possible. The color correction effects in X don’t match those in 7, so there’s no correlation between the two. You could render out a “flattened” master file from X and bring that back into 7 if you like. Then the color correction will be “baked” in.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Doug Metz
    April 13, 2016 at 8:27 pm
    As Oliver pointed out, the only way to do this is export video with baked-in correction. In some cases, you may also see a gamma shift when you bring your newly exported file(s) into 7.
    I guess I’m wondering why you wouldn’t simply finish the project in FCPX, now that you’ve got it in there…
    Doug Metz
    Anode
