Activity Forums Apple Final Cut Pro FCP X Keeps hanging
  • FCP X Keeps hanging
    Posted by Will Granzier on July 13, 2012 at 10:31 am
    Hi All
    Running the new FCPX 10.04 here…. Simple little 5 min edit…. Shot on JVCHM100 in MOV 720 XD cam codec… Edits fine… No problem…. Beautifull…. But just 5 layers of text onto of one another and the system goes ape…. It hangs…. Beach Ball …. Wont play back…. Wont export…. NADA !
    Remove it and its happy…. The Text is simple text created using the Custom Text Generator…. No heave graphics nothing …. Just TEXT !!!!
    Im using an iMAC 27inch i5 – 16gigs ram – Thunderbolt Drive
    This happened before… All ok just don’t add text !!
    I really think if Apple wants us to support this product they need to get it right !
    T. Payton replied 14 years, 2 months ago 4 Members · 4 Replies
  • Oliver Peters
    July 13, 2012 at 1:08 pm
    [Will Granzier] “All ok just don’t add text !!”
    But it’s not “just text”. Each Title and Generator is a Motion project. Will it render? Is it OK with 4 and then the 5th causes problems? Have you tried other Title effects/templates? Maybe something wonky with that effect. Or make a copy, edit it Motion and see if the copy works OK.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • T. Payton
    July 13, 2012 at 2:54 pm
    I just did a quick test on my very underpowered MacBook Pro 2007 with just 4GB of RAM and I was able to play 5 stacked “basic title”. I tried “custom” and got some dropped frames but not beach ball.
    Could be a corrupted font. Try switching fonts.
    Also the “custom” text generator actually has a lot of animation properties built in, like Oliver said. If you don’t need that use the “Basic Text” instead and see if that helps.
    T. Payton
    OneCreative, Albuquerque
  • Nick Toth
    July 13, 2012 at 4:39 pm
    I have a similar system to yours. I do a lot of local and regional commercials. Multiple layers of text clips always bog down my system. That being said, I am asking it to do a lot with as many as 15-20 video and text layers with effects, color correction, multiple formats on the time line. Once I looked at it from that perspective it didn’t look so bad. I render sections when I have to, keep “background” rendering set to 30 seconds so that if I’m away from the edit system rendering kicks in or I just find something else to do while the whole piece renders. I have submitted feedback requesting improved performance under these circumstances. I know they read feedback because I have gotten responses in the past.
    NT
  • T. Payton
    July 13, 2012 at 6:07 pm
    I did composite heavy spot a month ago and I found that actually the .5 second background rendering worked really well. Rarely did I ever have to wait for a render, it was just done as I was tweaking.
    If you have a bunch of layered text effects you might consider creating your own Motion template with perhaps many different text objects. That way FCP X is only rendering one motion project, rather than a stack of a whole bunch. The text generator “Feature” is an example of this.
    T. Payton
