Activity Forums Apple Final Cut Pro FCP X IMPORT does not recognize RAID Drive Files & Folders. Only see one directory and displays CLIP #1, # 2, #3 etc.
  • FCP X IMPORT does not recognize RAID Drive Files & Folders. Only see one directory and displays CLIP #1, # 2, #3 etc.
    Posted by Harry Rabin on July 30, 2017 at 5:19 am
    So it use to see the File and folder structure just fine but for some reason it only points at a specific folder and renames the files in that folder with CLIP # and increments this name for each file ending in Clip # 21??
    All other RAID drives work fine.
    Stumped and I believe this happened during an upgrade of FCP X.
    I have attached screenshots that show the Finder view vs. the FCP Import view of same RAID Drive.
    Any suggestions FCP X gurus??
    Harry Rabin replied 8 years, 9 months ago 3 Members · 5 Replies
  • Duncan Craig
    July 30, 2017 at 9:29 am
    You’re not really helping yourself much here.
    What OS and version are you running?, what versions were you running?
    There’s was an update a few years age which changed how my FS100 AVCHD footage was named on import. It now shows as Clip#1 Clip#2 etc.
    FS100, EX1, GoPro, 2x Hacks, FCPX etc
  • Harry Rabin
    July 30, 2017 at 1:42 pm
    I am running version 10.2.3, Mac OS X SIERRA 10.12.3
    The Screen Shots:
    FINDER VIEW of RAID DRIVE:
    FCP X ver 10.2.3 view of RAID DRIVE
  • Duncan Craig
    July 30, 2017 at 4:03 pm
    10.2.3 is quite possibly the culprit. The clips look perfectly normal to me as the associated timecode is continuously increasing. Can I assume it’s AVCHD footage?
  • Bret Williams
    July 31, 2017 at 5:34 am
    I believe it’s seeing your drive as a camera/card because you have a raw card structure at the root of the drive. THe folder named “private” perhaps?
    If that’s the case you need to put that in a directory and it will once again see it as a drive, not a card.
    _______________________________________________________________________
    https://BretFX.com FCP X Plugins & Templates for Editors & Motion Graphics Artists
  • Harry Rabin
    July 31, 2017 at 6:42 am
    You were 100% correct. THANK YOU THANK YOU! It was the classic drag it from the memory card to a folder and it missed and went to the root directory. Learn something new everyday! I owe you one!
