Activity › Forums › Apple Final Cut Pro › FCP X Hangs on launch at “loading compressor support” screen – ideas?
Isaac De icaza replied 13 years, 6 months ago 10 Members · 17 Replies
Scott Bellefeuille
October 8, 2011 at 4:49 pmSorry, but I never found a fix for this. I ended up losing all the work I had done on the event and project. Your only hope would be if you had a backup of the project and/or event data files. Good luck!
Richard Taylor
October 8, 2011 at 5:37 pm -
Gordon Macnaughton
October 9, 2011 at 10:08 pmJust downloaded the free trial of FCPX and even that is freezing at loading compressor support window, any idea? Cheers
Louis Abate
November 4, 2011 at 7:46 pmSame thing happening to me… Just made the switch over from FCE about 2 weeks ago. Running into a number of weird issues including screen digitizing into nonsense, timelines not showing up, and now it won’t even boot. I pulled my external drives, try removing project files, to no avail. On the phone with Apple support now (or should I say, on hold…). I’ve spent about 30 hours in the software and was really starting to like it… man.
Jamie Harbison
November 28, 2011 at 2:49 amThis worked for me too.
Just launch Compressor, and leave it open. Then launch Final Cut Pro X.
Happy days
Bryan Housley
November 15, 2012 at 5:51 amI have had the same issue, loaded the app “Compressor” and then rebooted FCPx, and it works like a charm. Hope they have a software update that doesn’t inconvenience me like this every time.
Isaac De icaza
February 8, 2013 at 7:06 amI had this problem. I was working in the previous model to the first unibody macbook pro. 15”. The computer freeze at “loading compressor support.” So first thing I tried was to plug my external hard drive to a newer mac (macbook pro 13” i7) and FCPX (also known as iMovie pro) finally finished the loading but as soon as I tried to open the project I was working on the program crashed and had to force to quit and start again. Back to my old macbook pro I tried clearing my preferences as suggested in this post and launch FCPX again for the first time it had opened since the problem first appear (and my file got corrupted). But I got the same issue as soon as I selected the project it crashed. But after several crashes I came up with the idea (I don’t know why) of dragging the project to my computers hard drive and it made a copy try to run the program again and there was no recovery file so I copy that file and un-plugged the external hard drive again (where all my files are). This time the project loaded ass offline clips but it didn’t crash as quick as alway. I managed to select it and export a XML.
It’s not the greatest solution, all the on FCPX adjustments are lost but I have the clips layout and just have to re-check every thing now. Again…not great but it was the only way for me for not starting from 0 again.
I hope this helps somebody the way some posts have helped me in the past.
Let’s hope next FinalCut it’s actually an upgrade.
