Activity › Forums › DaVinci Resolve › fcp x export xml to davinci resolve; path problem?
  • fcp x export xml to davinci resolve; path problem?
    Posted by Theo Peeters on January 17, 2013 at 2:45 pm
    I have fcp X 10.0.5 and da vinci resolve 9 lite.
    I export from fcp a fcpXML to the desktop and I try to import the XML in resolve, but
    I got the message :46 clips were not found Do you want to select another folder to search ?
    If I say yes and try to find the xml on my desktop, I do not find it, nor on another place.
    I was given an answer that : Its usually a database/default path fault.
    Is it and if so, how do I solve the problem?
    Theo Peeters replied 13 years, 8 months ago 1 Member · 1 Reply
  • Theo Peeters
    January 21, 2013 at 6:42 pm
    Is there no solution for the problem?
