Activity Forums Apple Final Cut Pro FCP X Effect: BG Custom Angle Wipes
  • FCP X Effect: BG Custom Angle Wipes
    Posted by Brendan Gibbons on August 21, 2011 at 12:08 am
    BG: Effects in FCP X
    “BG Custom Angle Wipes”
    This is an FCP X Effect preset.
    This FCP X effect preset enables you to add custom angle wipes / masks to your image, not as a transition but as an effect.
    Therefore you can choose to animate / keyframe the effect any you like or just use it as a static mask.
    Download FCP X: BG Custom Angle Wipes
    There are many different uses for this effect:
    – Reveal a layer on over black / background of your choosing
    – Create an angled wipe between 2 or more different layers (add a layer on top and apply the effect to this layer)
    – Use the preset to wipe / reveal on text or logos
    – Use the wipe between 2 of the same clips, one with a colour effect applied, one without, and create a nice blend between the two.
    – Use as a colour correction before / after wipe tool when working with clients. (duplicate graded layer, remove grade and add wipe preset)
    – Sadly no option in this version to make a good cup of coffee…Apple have not released the API’s for that yet 😉
    Preset Controls:
    – Four built in wipe presets: From Top Right, From Top Left, From Bottom Right and From Bottom Left
    – Wipe amount control
    – Wipe softness / falloff control
    – Small refinement of wipe angle
    – Reposition / Rescale the image within the masked area
    Screenshots:
    Inspector Controls:
    Drop the folder inside this zip called BG Custom Angle Wipes into the following directory:
    Movies / Motion Templates / Effects / BG Effects /
    Cheers,
    Brendan
    Simon Ubsdell replied 15 years, 1 month ago 3 Members · 3 Replies
  • Brendan Gibbons
    August 21, 2011 at 1:15 am
    Here’s a video giving you an idea of some of the ways BG Custom Angle Wipes can be used
    FCP X Effect: BG Bag of Tricks
    Cheers,
    BG
  • Pat Harris
    August 21, 2011 at 2:03 pm
    Looks great! Thank you so much for taking your time to make all of these effects and presets for fcpx. You are a very kind and generous person!
    Pat Harris
    -Cinematic DSLR
    – RTN Post Production Supervisor
  • Simon Ubsdell
    August 21, 2011 at 8:10 pm
    Nice idea – will be very useful.
    Here’s something similar I was playing with:
    2836_archive.zip
    Two related effects for shaping the lighting of an image, one for darkening the edges and the other for lighting up a “spotlit” area, with options for blur and glow.
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
