Activity Forums Apple Final Cut Pro FCP X Effect: BG A Little Mood Lighting Please
  • FCP X Effect: BG A Little Mood Lighting Please
    Posted by Brendan Gibbons on July 22, 2011 at 7:49 pm
    A simple FCP X Effect preset, using a Motion lighting source to help give a dynamic mood and lighting effect to you shots.
    FCP X Effect: BG A little Mood Lighting Please
    – Position, Rotate light Source
    – Choose light source colour
    – Light source intensity, falloff, angel and softness control
    – Light mix control to balance the effect back against the original image
    – You could make the light hard edged an use it to highlight a face in a crowd if you really wanted!
    Best of all, if you don’t like it or it doesn’t quite suit… open it in motion and tweak away.
    Screenshots: (In honour of the newly released roaring one!)
    Splitscreen showing before on the left, and after effect applied on the right.
    Controls:
    Install Location:
    Drop the folder inside this zip into the following directory:
    Movies / Motion Templates / Effects / BG Effects /
    For full installation instructions if you don’t have Motion 5 please refer to README file inside the zip file.
    Cheers,
    Brendan
    Brendan Gibbons replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
