Activity Forums Apple Final Cut Pro FCP X doesn’t support transparency?
  • FCP X doesn’t support transparency?
    Posted by David Tannenbaum on November 30, 2011 at 7:46 pm
    Is it my imagination or does FCP X doesn’t support transparency? I made a lower third in After Effects with an alpha channel and partial transparency on the lower thirds box containing the title of the person. The alpha channel worked in FCP X but the partial transparent box that allowed the video underneath to show in After Effects did not appear as a partially transparent box in FCP X. Is this right or do I need to turn something on via a check box.
    David Tannenbaum replied 14 years, 9 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    November 30, 2011 at 10:03 pm
    [David Tannenbaum] “I made a lower third in After Effects with an alpha channel and partial transparency on the lower thirds box containing the title of the person. “
    In what format? Have you tried modifying the alpha type in the info window (must be set to settings view)?
  • David Tannenbaum
    November 30, 2011 at 11:49 pm
    my mistake. The transparency was produced in AE by the layer modes settings but the opacity was 100%. Once I changed the opacity in the AE file to anything less than 100% then I got the desired effect. (I knew something was up when the same problem manifested in Premeire too)
    Thanks for your response
