Activity › Forums › Apple Final Cut Pro › FCP X Consolidate Not Working
  • FCP X Consolidate Not Working
    Posted by Brett Sherman on March 14, 2018 at 4:25 pm
    So this is the way I want to work. I make an edit in a FCP X Project. I may pull clips from other Library files. I want to leave the files in place until I’m finished. Then once I have a finished edit, I want to Consolidate all the files I used into the folder I’ve designated in the Library Storage Locations.
    I thought the “Consolidate” button would do this. It doesn’t. In fact, it seems to do nothing. No files are copied. Nothing happens. What is going on here. How can I get it to do what I want?
    Before Consolidate:
    After Consolidate:
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
    Andreas Kiel replied 8 years, 6 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    March 15, 2018 at 10:26 am
    Can you give exact steps, as this process should work.
  • Brett Sherman
    March 15, 2018 at 12:36 pm
    Yeah it worked at one time. I don’t know if it has anything to do with SMB storage. I mean it’s pretty simple.
    I set up a new library. Create an external media folder. Set that as the storage location for Media and Cache. Then I import new footage into that folder.
    Then if I need to grab a shot from another library I open that library and copy and paste or insert a clip in my project timeline. I keep preferences at “Leave files in place” because I don’t want to copy the media over at this point.
    Then once I’m finished. I just simply hit the “Consolidate” button and wait for the magic to happen. It doesn’t, it seems to copy a single file or something that takes about 10 seconds then stops. All the media remains where it is. Even if I change the preference to “Copy files to storage location”. Which I shouldn’t have to do anyways.
    I’ve even tried exporting an XML of the timeline. Importing the XML into a new library. But no dice. Still no files get copied.
    At this point are there any products that will do this outside of FCP X.
    Brett Sherman
  • Brett Sherman
    March 15, 2018 at 12:40 pm
    Actually what I really want is a utility that will look at an XML file. Allow me to set a folder location. Then only copy files that are not on the same drive as that folder because I just want it on the same drive. It doesn’t have to all be in the same folder. But I’d be happy if the Consolidate function actually worked.
    Brett Sherman
  • Jeremy Garchow
    March 15, 2018 at 2:03 pm
    This process works for me so I’m not sure why it wouldn’t work for you. Perhaps it is SMB, I don’t know.
    Can you push media to the second library? So, create your new library, open the old library, select clips and “File > Copy to…”?
    Otherwise, there’s media copy from automatic duck that will consolidate an xml.
    https://www.automaticduck.com/#media-copy
  • Andreas Kiel
    March 15, 2018 at 8:21 pm
    Brett,
    I made a little utility which lists all AV files from any XML – project, event, lib. Drag any of those to the app window’s table view or import an XML
    You can select a drive and it will list the missing ones. It can do more, but there’s no documentation.
    https://www.spherico.com/filmtools/X-Files/X-Asset/XAU.dmg
    It’s free.
    – Andreas
    Spherico
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
