Activity › Forums › Sony Cameras › FCP-X cannot export to Sony Content Browser ver 2
  • FCP-X cannot export to Sony Content Browser ver 2
    Posted by Chandraseegar Krishnan on October 5, 2014 at 8:57 am
    Hi, i am struggling to export my video to mxf format using fcp x.
    its seems the menu export to SCB (Sony Content Browser) not exist.
    I need to give mxf format xdcam imx30 to broadcast station for SD format.
    any input?…
    Thijn Teeuwissen replied 10 years, 11 months ago 3 Members · 2 Replies
  • Ian Cook
    October 6, 2014 at 2:09 pm
    You need to install Content Browser then set the Share–>’Open With’ action to ‘Content Browser Exporter’.
    Our export plugin simply takes the multichannel QT file and wraps it as an .mxf. Getting multitrack QTs out of FCP X is a bit of a process, however. You need to create new audio roles for each track, then assign those roles to the audio tracks, then map them to output tracks in the Export dialog. XDCAM 50 Mb/HD422 exports must have 8 channels of 24 bit audio. EX export (35 Mb .mp4-wrapped XDCAM) is regrettably not working at present as it is all but impossible to get 16 bit audio out of FCP X (even if you run it through Compressor the channel structure is incorrect). I am working on getting this fixed.
  • Thijn Teeuwissen
    October 23, 2015 at 9:37 am
    I use Content Browser also but I don’t see “content browser exportor” in my Share menu…
    Why is that?
    How can I fix that?
