Activity › Forums › Apple Final Cut Pro › FCP X and Time Machine
  • FCP X and Time Machine
    Posted by Michael Sanders on November 24, 2013 at 6:18 pm
    The other day in a moment of over excitedness I installed a driver which completely wrecked my system.
    It meant reinstalling the OS and for safety I decided to erase and start again. I only lost a tiny bit of stuff but am still reinstalling various pieces of software, plug ins etc.
    So with that in mind I want to get a more robust back up system in place for this machine. I’ve got a Drobo FS which backs up the other non edit machines in the house but was wondering what peoples thoughts are about Time machine on edit computers – specially running FCP X. Will I notice anything major in terms of time lag? Or should I just go the permanently connected drive route and use Carbon Copy Cloner?
    I never keep media on here (except as a temporary 3rd location when using SPP) so it’s never going to be backing up loads.
    Cheers.
    Michael
    Michael Sanders
    London Based DP/Editor
    Nick Toth replied 12 years, 10 months ago 4 Members · 3 Replies
  • Claude Lyneis
    November 24, 2013 at 6:50 pm
    I found Time Machine got in the way because I needed all the computing power when I was editing. I use a standalone backup program (Super Duper), but not while editing. On the other hand, I didn’t pursue all the possibilities with Time Machine.
  • Petter Stahre
    November 25, 2013 at 9:47 am
    I’m using Time Machine and I’m very happy with that.
    I can’t say I notice any particular lag, but when I edit under time pressure I tend to watch if TM is doing a backup and if it is then I’m suspending TM just to make shure.
    My impression is that editing gets slightly affected when TM is working, but I haven’t done any “scientific test” 🙂
    When Finder copy files on my machine it uses up to 7% of the CPU. I would expect TM to have the same usage as a maximum.
  • Nick Toth
    November 25, 2013 at 1:00 pm
    I have Time Machine back up my system drive. I haven’t noticed any effect on system performance.
    I use Carbon Copy Cloner to back up my media RAID however because I don’t necessarily want to back up every single file that is on my media drive. I use Event Manager X and backing up via Time Machine can cause redundant file backups, for instance if it backs up while a project is active and then again when the same project is inactive you get duplicate backups.
    It’s not automatic but I prefer not to be on automatic when it comes to media files. At the end of the day I use Event Manager X to take all projects and events offline and then back up with CCC.
    anickt
