Activity Forums Apple Final Cut Pro FCP X 4:3 to 16:9 Pillarbox effect
  • FCP X 4:3 to 16:9 Pillarbox effect
    Posted by Benjamin Higginbotham on November 8, 2011 at 3:15 am
    Hoping someone in the community can help me.
    I’m trying to create a pretty simple pillarbox fill effect. My project is a 16:9 1080p canvas and I have some 4:3 content. Rather than just have standard black pillarboxes, I would like to fill them with the 4:3 content. In FCP 7 what I would do was duplicate the layer. On the lower layer I would zoom in to around 180% and add a gaussian blur. On the upper layer I would add a 2px crop on the left and right, zoom in to 101% and add a soft drop shadow with a 0 distance to give a bit of seperation between the top and bottom. The effect worked really well.
    Problem is, I can’t seem to replicate it in FCP X. I thought maybe I could be all fancy and create a motion effect template that does all of this in one layer (and holy cow would that be awesome). But it appears as though the effect can’t go above and beyond the size of the original video. That means any distortion I did was confided to a 4:3 window.
    So then I tried to replicate the effect in FCP X. I can get most of the way there with a blurred lower layer and a top layer that is sized right. But once again I run in to a problem with the drop shadow. It seems that any drop shadow I try and add is also confined to the original 4:3 video size and can drop outside of that as it could in FCP 7.
    I’m hoping there is just an uber simple solution I’m not thinking of. Seems to me this is a pretty common effect and a great way to get 4:3 content to look better in a 16:9 canvas. Any thoughts from the community?
    Spacevidcast.com
    benjamin@spacevidcast.com
    Simon Ubsdell replied 14 years, 9 months ago 7 Members · 10 Replies
  • 10 Replies
  • Don Smith
    November 8, 2011 at 12:58 pm
    The drop shadow is there but you don’t see it because the 4×3 video has to shrink within it’s 4×3 frame in order for you to see the drop shadow. In shorter words, the drop shadow is being applied to the video and not to its container. Without shrinking the video, the container is limiting your view.
    RippleTraining has some free effects to accomplish this but you can create your own in a couple of minutes.
    Create a new effect (doing this off the top of my head) and publish the scale control so you can shrink the video inside the placeholder and thus reveal any drop shadow you apply to it. You’ll also have to publish the drop shadow controls for the video as well. I’m sure I’m leaving out a detail or two trying to convey this without Motion in front of me, but you seem savvy enough to fill in those details.
    NewsVideo.com
  • Don Smith
    November 8, 2011 at 12:59 pm
    I also meant to mention above that you scale down your video within the placeholder but then scale up the placeholder itself so that you can see a drop shadow but still scale the whole thing to 101%.
    NewsVideo.com
  • Andy Neil
    November 8, 2011 at 11:49 pm
    Though it’s not impossible to create this as an effect, it’s pretty easy to do outside of motion. In fact, it’s done the same way that you do it in FCP 7.
    Duplicate the clip. Scale the lower clip to whatever you need to in order to make it fit in the 16:9 frame without pillaring. Apply a blur effect to the footage.
    Crop the top layer, scale it if you like, and add the drop shadow.
    Andy
    https://www.timesavertutorials.com
  • Tom Wolsky
    November 8, 2011 at 11:55 pm
    The problem is the drop shadow; there isn’t for video clips in FCP. A guess you could fake one with a generator of matching size.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Andy Neil
    November 9, 2011 at 12:02 am
    You know, I’ve got to stop posting when I don’t have my X beside me. I don’t know why I thought there was a drop shadow. Perhaps because it’s so similar in UI to Motion now. Ok. I take it back, the easiest thing would be to create a pillarbox effect in Motion. Just clone the placeholder then scale and blur the lower one.
    Andy
  • T. Payton
    November 9, 2011 at 12:51 am
    Quick solution for you. Just precompose the 4×3 shot in a 16×9 compound clip.
    Then it is easy to do the rest in Motion. Here is an effect to get you started.
    3223_fake16x9blurfootage.zip
    T. Payton
    OneCreative, Albuquerque
  • Wayne Garton
    December 4, 2011 at 1:45 am
    I have tried using this effect but I must be doing something wrong because the effect works great on-screen in FCPX, but when you export out the file, the background (enlarged, blurred, faded) is missing and instead you are left with just black borders on either side of the 4×3 footage.
    So here is what I am doing!
    Go into project bowser, click on project properties; the spanner, change to amorphic 720×576
    1 Place 4×3 footage on timeline
    2 Place duplicate footage above as a connected clip
    3 Click on bottom clip -click spatial conform and Fill
    4 drop on fake 16×9 blur footage effect on bottom clip
    5 Adjust to make it look required
    6 Share / Export Media
    Cheers
    Wayne
    New Zealand
  • T. Payton
    December 4, 2011 at 5:22 am
    I just tried this and I see that the exported version is darker that what is seen in FCP X. Perhaps that is what is happening. See here: The one of the left is the QT export, on the right the FCP X interface:
    I made that effect pretty quickly, it was more of a proof of concept. Perhaps it is something I did wrong. But the quick fix seems to be to bump up the opacity.
    T. Payton
  • Wayne Garton
    December 4, 2011 at 6:45 am
    I’ll give it a go
    Since tried raising the transparency from 8% to 25% and it is now about the same after exporting as the 8% before export. Great, at least I know it now works and I can allow for the difference
    Cheers
    Wayne
    New Zealand
  • Simon Ubsdell
    December 4, 2011 at 9:59 am
    x
