Activity Forums Apple Final Cut Pro FCP X 10.2.3 backwards compatibe with 10.2.2?
  • FCP X 10.2.3 backwards compatibe with 10.2.2?
    Posted by Mark Hayes on March 23, 2016 at 9:47 pm
    I was installing a the new Apple security update and accidentally updated FCP X from 10.2.2 to 10.2.3. I am working on a large project with others who are using 10.2.2. Will this wreak havoc with the others. We are sharing transfer libraries etc.
    If I need to re install 10.2.2 is there an easy way? I do have a Time Machine backup that is quite old but it would work if there is no other way. 10.2.3 seems like an incremental backup and maybe it doesn’t make a difference and in fact is backward compatible to 10.2.2.
    If I have to reinstall 10.2.2 is there a link I can use so I don’t have to do a time machine restore and lose lots of other stuff I have installed?
    Thanks for any help.
    Mark
    Mark Hayes
    Noah Kadner replied 10 years, 1 month ago 3 Members · 3 Replies
  • Jeremy Garchow
    March 23, 2016 at 10:19 pm
    Just drag the 10.2.2 app out of your time machine backup and add it to the Applications folder (replacing 10.2.3).
    I do think they are backwards compatible.
  • Mark Hayes
    March 23, 2016 at 10:34 pm
    Thanks. Will try it.
    Mark Hayes
  • Noah Kadner
    March 24, 2016 at 2:09 am
    Can’t see a reason why you’d want/need to downgrade but the Project format wasn’t updated so it kinda doesn’t matter either.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
