Activity Forums Apple Final Cut Pro Legacy FCP Workflow with HDV / HD / DV footage
  • FCP Workflow with HDV / HD / DV footage
    Posted by Stephen Vilas on April 27, 2009 at 7:02 pm
    I am working on a feature documentary (90min) with final delivery in HD as well as SD.
    At the moment, I have the following footage
    1) XDCAM EX1 1080p25 footage (1920×1080) – about 60 to 70 percent was shot in this format.
    2) HDV 1080p25 (actual frame size 1440×1080) shot with a Canon XL-H1 (about 20 percent of the footage was shot in this format)
    3) DV-PAL footage (archival footage in 4:3 and some of it in 16:9)
    4) some web footage of different sizes but very few clips of these
    The sequence settings I will use in FCP 6 are the following:
    I have not converted my XDCAM 1080p25 footage to the Apple ProRes codec, since its still very smooth to edit with, so I assume this is ok until I have my finished version which i will then render out to Apple ProRes for colour grading.
    My question is what I should do with the other footage?
    1) How should I convert the HDV footage so it will fit with these settings? Should i convert everything to 1920×1080 1080p25 with Compressor (using the Apple ProRes High Quality codec) ? How bad would the loss of quality be? Unfortunately I dont really have the budget to get a Kona3 to upscale so wondering if this is the best approach. Or should I just convert it to Apple ProRes but keep the original frame size?
    2) I will upscale and convert the DV Pal footage using InstantHD plugin with FCP. Is this the best way for my workflow or should I use Compressor as well?
    3) some of the web footage is very rare footage that is unavailable on any higher format. Should I also use InstantHD or should I consider going to a professional facility for conversion? Will it make a big difference in quality?
    thanks in advance for your help
    Stephen Vilas replied 17 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Kent Stipp
    April 27, 2009 at 8:57 pm
    Stephen,
    As we all know HDV footage is long GOP and well difficult at best to edit. I would suggest choosing a suitable ProRes 422 Format like Pro Res 1280×720 60p or something like that and that way it will also be more editable for you. you can do the same basic thing with your DV footage by upconverting it on ingest.
    Hope this helps
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
  • Stephen Vilas
    April 27, 2009 at 9:08 pm
    thanks Kent for the reply.
    why 1280×720 though? wouldn’t it be better to have all the footage on the same frame size of 1920×1080 (as the rest of the XDCAM EX1 footage) or is that not recommendable at all?
  • Kent Stipp
    April 27, 2009 at 9:12 pm
    i was just using that Pro Res codec as an example, it was the first one off the top of my head. the best of course is match as close as possible to the other footage ( if and when possible)
    Kent Stipp
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
  • Michael Gissing
    April 27, 2009 at 10:42 pm
    Stephen, the best approach is to use one codec but the decision to do that should be made in pre production. ProRes is probably the best to chose. At this stage with most of the footage in XDCam, your sequence is probably better left as XDCam that matches exactly your clips and convert the other footage to ProRes 1920 x 1080 so you pixel aspect is common.
    To do that open a new sequence, drag one XDCam clip into the sequence and it will ask to alter the settings to match the clip. Say yes and make note of the settings. Adjust your Easy Setup to those settings and you will have minimal rendering/ RT issues. As an XDCam sequence you can set your renders to be ProRes which is a good way to go
    I note with alarm that your audio setting is 44.1 which is wrong and a disaster waiting to happen as all your audio is 48Khz.
    The important thing though is what are you delivering? If it is broadcast you will need to deliver 1080 50i on HDCam (or SR).
  • Stephen Vilas
    April 28, 2009 at 10:42 am
    [Michael Gissing] “Stephen, the best approach is to use one codec but the decision to do that should be made in pre production. ProRes is probably the best to chose. At this stage with most of the footage in XDCam, your sequence is probably better left as XDCam that matches exactly your clips and convert the other footage to ProRes 1920 x 1080 so you pixel aspect is common.
    thanks, Michael, this seems to be the best approach. Will compressor be the best app for converting the HDV footage to 1920 x 1080 ProRes? I assume there will be some loss of quality by converting this footage, but I assume this is not too much of a problem?
    Yes, thank you for pointing that out. I checked and most of the sub sequences I am working with had the 48Khz setting, but the main sequence had other audio settings for some reason. thanks very much. by focusing on the codec and frame size issues I didn’t pay attention the audio settings!
    The important thing though is what are you delivering? If it is broadcast you will need to deliver 1080 50i on HDCam (or SR).”
    There will be different versions.
    One delivery format will be for broadcast, but since most of the channels here in Europe don’t broadcast in HD yet, a DigiBeta copy will be enough. I aim to have an HD Master of my current settings (1920×1080 ProRes HQ) which I will then send to a duplication facility to make the necessary copies to HDCam tape and DigiBeta. Can I keep my current settings if I want to render out my digital master file or should I adjust the field dominance? (I know 1080p25 is not available as aspect ratio setting in FCP, so I assume the HDTV 1080i aspect ratio is the one i want to keep for the master as well)
  • Nick Price
    April 28, 2009 at 3:30 pm
    HI stephen,
    i have found much better results using compressor to upscale footage, DV/HDV to Prores, making sure you turn on ‘Frame Controls’ in your compressor setting. This gives a much better version that FCP doing the rendering, but it will take a LONG TIME!! I would finish off the project, media manage to just the clips you want and uprez that in compressor. There should be a way to replace the clips automatically if you are clever with your file naming.
    As you say hardware conversion at a posthouse or with the kona for example would be preferable, but again as you say, not to everyones budgetary tastes…
    good luck
    nick
  • Stephen Vilas
    April 28, 2009 at 4:11 pm
    thanks, Nick. there’s some great advice. I had done some tests already without frame controls and considering the amount of footage I have for this film, it might indeed be a good thing to use Media Manager when the final cut is ready and only convert the HDV/DV footage I will use. I was already going to add a couple 1TB disks more to the Mac Pro but even then it would be a tight fit, considering the size of ProRes footage.
    do you have any suggestions regarding frame control?
    Should I by default set the anti-alias and detail sliders to the maximum?
    I want to have a 1080p25 master at the end, so I’m assuming I should always set output fields to progressive, but not sure what the best approach is for de-interlacing. Reverse telecine for HDV and DV footage or is that not necessary?
    thanks for your help anyways!
