  • Posted by Michael Nielsen on December 1, 2008 at 4:01 pm
    I’m looking for some advice on improving my FCP workflow. I am currently editing in FCP on a Dual 2.3 G5 with 14GB of RAM, with a 23″ Apple Cinema display. I want to add a second display for monitoring and color correcting, but not sure what route to take.
    I shoot with a Sony EX3 generally in 720p/24, sometimes 1080p/24. I am considering a Blackmagic Decklink HD Extreme as a starting point, and monitoring on an HD LCD. Is there a better option? Or does anyone have a suggestion for an LCD monitor that would be good for color-correcting?
    Another reason I am looking at going this route is that I also need an LCD monitor that can double as a studio monitor when I shoot. I was considering purchasing Blackmagic’s HD Link Pro to monitor using my Apple Cinema Display, but depending on what second LCD monitor I purchase, and what the inputs are, I may not need this.
    Any suggestions? Or do I need to provide more information?
    Thanks.
    Michael
    Tim Kolb replied 17 years, 10 months ago 2 Members · 1 Reply
  • Tim Kolb
    December 2, 2008 at 2:37 am
    Two parts to the color correction question…
    1. where is the signal coming from? As long as you’re feeding out of the BM card and not from a display card in the computer itself, you should be accessing a relatively accurate signal relative to your final output.
    2. Monitor…if it’s an LCD you’re after and you aren’t in the mood to pony up 13-25 thousand, I’d check out the JVC LCD production monitors…they have some models that will take a legitimate video signal (analog component and/or HDSDI) as opposed to something that only accepts a signal as an adapted RGB signal on DVI…
    TimK,
    Director, Consultant
    Kolb Productions,
