Activity Forums Apple Final Cut Pro Legacy FCP won’t start
  • FCP won’t start
    Posted by Chris Brown on June 28, 2011 at 8:23 am
    Hi
    I’ve been having problems installing final cut studio 2 after installing final cut studio 3, were the final cut option way greyed out and stated it would be skipped your install. I got around this by using the FCS romver. So i can now install fcp but when i go to launch the app i get the following error:
    Process: Final Cut Pro [198]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: ??? (???)
    Build Info: FCPApp-706230001~3
    Code Type: X86 (Native)
    Parent Process: launchd [112]
    Date/Time: 2011-06-28 09:17:40.927 +0100
    OS Version: Mac OS X 10.6.8 (10K540)
    Report Version: 6
    Interval Since Last Report: 126016 sec
    Crashes Since Last Report: 507
    Per-App Crashes Since Last Report: 2
    Anonymous UUID: D078FA7D-43BA-4DF3-876A-E188124EBC6E
    Exception Type: EXC_BREAKPOINT (SIGTRAP)
    Exception Codes: 0x0000000000000002, 0x0000000000000000
    Crashed Thread: 0
    Dyld Error Message:
    Library not loaded: /Library/Frameworks/ProFX.framework/Versions/A/ProFX
    Referenced from: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Reason: image not found
    Binary Images:
    0x8fe00000 – 0x8fe4162b dyld 132.1 (???) <283EE026-C0FE-1FF9-DB81-BFB155793157> /usr/lib/dyld
    Model: iMac12,1, BootROM IM121.0047.B0A, 4 processors, Intel Core i5, 2.7 GHz, 4 GB, SMC 1.71f21
    Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 512 MB
    Memory Module: global_name
    AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.35.3
    Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
    Network Service: AirPort, AirPort, en1
    Serial ATA Device: WDC WD1001FALS-403AA0, 931.51 GB
    Serial ATA Device: HL-DT-STDVDRW GA32N, 4.36 GB
    USB Device: FaceTime HD Camera (Built-in), 0x05ac (Apple Inc.), 0x850b, 0xfa200000 / 3
    USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
    USB Device: USB-PS/2 Optical Mouse, 0x046d (Logitech Inc.), 0xc01d, 0xfa130000 / 5
    USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
    USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0xfa111000 / 6
    USB Device: Hub, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
    USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0xfd110000 / 4
    USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0xfd120000 / 3
    FireWire Device: unknown_device, Unknown
    Any help would be great
    cheers
    chris
    Tony Silanskas replied 15 years, 2 months ago 2 Members · 1 Reply
  • Tony Silanskas
    June 28, 2011 at 9:23 pm
    This might not help you, but did you backup your system before you updated? Can you copy that backup back to your main drive and try again?
    tony
    http://www.HungryCliff.com
