Activity Forums Apple Final Cut Pro Legacy FCP won’t recognize the camcorder.
  • FCP won’t recognize the camcorder.
    Posted by Steve Tamou on August 22, 2011 at 10:35 pm
    I was capturing some DV tapes with log and capture and did a few tapes. After doing about 4 tapes, FCP will not recognize that the camcorder is hooked up anymore. I did not mess with the settings. I tried restarting the computer and hooking up the camcorder again via firewire and it still won’t recognize it. Does anyone no what the problem might be. I’m using FCP 7. Thank You.
    Steve Tamou replied 15 years ago 1 Member · 1 Reply
  • Steve Tamou
    August 23, 2011 at 3:33 am
    OK. I got it to work. It may have been a loose firewire connection on the camcorder side but I’m not sure. Thank you all.
