Activity Forums Apple Final Cut Pro Legacy fcp won’t recognize sony dsr20 dvcam deck
  • fcp won’t recognize sony dsr20 dvcam deck
    Posted by Chris Gorman on October 17, 2010 at 11:54 pm
    FCP6 says it cannot “initialize” my fw video deck. fw audio settings are greyed out in the device settings. It used to work fine, but this is the first time I’m trying to output to tape (dv ntsc sequence), since I hooked my mxo a few years back.
    Could my mxo interfere with my setup for communication with my firewire sony dsr20 dvcam deck?
    My deck is working…I can see the output when it’s connected to my ntsc monitor, and it’s “record” function is working. The fw cable is not a problem because it works capturing from my Sony hdv Z1U.
    I’ve tried every possible setting in the av settings. Should I disconnect the mxo stuff.
    PowerPC G5 DP2.3, 4GB DDR SDRAM, ATI X800XT, OSX.4.11, QT 7.5.5, FCStudio2, FCP 6.0.5 Sonnet 5 Bay SATA (RAID or JBOD as needed), ACD 23″ & Sony NTSC Monitor via Matrox v.1
    Sony ZIU hdv, edit w.ProRes
    Chris Gorman replied 15 years, 10 months ago 1 Member · 1 Reply
  • Chris Gorman
    October 18, 2010 at 1:48 am
    It was too late to delete this post, but I just now solved the problem. I did have to unhook the mxo and re-cable. Works now. An inconvenience I guess I’ll have to live with when switching workflow.
