Activity › Forums › Apple Final Cut Pro › FCP won’t recognize Motion?
Jeremy Garchow
April 29, 2013 at 6:15 pmThe free Preference Manager from Digital Rebellion should help you.
Jeremy
Ignacio Holiday
April 29, 2013 at 8:40 pmThanks for the tip. I installed the program and trashed the preferences but I’m still getting the same message. I re-installed Motion too and it didn’t seem to help.
Jeremy Garchow
April 29, 2013 at 9:30 pmJust to see if this works, let’s try going the other way, can you create a Motion template in Motion (use a “Final Cut Effect” or “Final Cut Generator”) and have it show up in FCPX?
Jeremy
Ignacio Holiday
April 29, 2013 at 9:56 pmYeah, FCP will recognize items made in Motion but not the other way way around apparently. They need a therapist to learn to communicate better.
Jeremy Garchow
April 29, 2013 at 11:10 pm[Ignacio Holiday] “They need a therapist to learn to communicate better.”
Certainly some creative counseling otherwise known as criticism.
If you make a new admin user does it work?
Ignacio Holiday
April 30, 2013 at 6:48 pmI’m not sure what you mean; if I sign in as guest I can’t run FCP.
Jeremy Garchow
April 30, 2013 at 6:53 pmYou have to create a whole new account.
Open Sys Prefs, Choose Users and Groups, create a new user with admin privileges.
Jeremy
Ignacio Holiday
May 1, 2013 at 3:27 amI’m just trying to modify a FCP title in Motion. It doesn’t matter which title or transition I click on, I get the same error message every time.
