Activity Forums Apple Final Cut Pro Legacy FCP WON’T RECOGNIZE FIREWIRE
  • FCP WON’T RECOGNIZE FIREWIRE
    Posted by Catama Productions on January 5, 2006 at 9:33 pm
    I booted up my G4 laptop which is connectoed to a DSR 11 via Firewire 400 Port as well as a Lacie External Firewire 800 Drive on the 800 Firewire port. The Lacie drive is recognized but FCP does not recognize firewire to the deck- in my AV settings, DV firewire is not even an option for external video. When I go to log and capture I can control the deck, I see audio in the meters but preview is disabled. I re-installed FCP 5 and that didn’t work. I tried Imovie and that shows that a Camera is connected and I can see video and capture it, so I know the firewire is working, just not in FCP. ANY HELP WOULD BE GREATLY APPRECIATED. THanks
    Michael Cocivera replied 16 years, 10 months ago 5 Members · 6 Replies
  • Marc Bostrøm
    January 5, 2006 at 9:42 pm
    follow this article:
    https://docs.info.apple.com/article.html?artnum=301852
    delete your FCP prefs
    Good Luck
    Marc Bostrom
    FCP & AE post production
  • Catama Productions
    January 5, 2006 at 9:53 pm
    Thanks but I have Quicktime 7 and I already have thrown out my FCP preferences. ?????
  • Peter Mcauley
    January 5, 2006 at 10:16 pm
    Read the article again. It’s not about FCP prefs and it doesn’t matter that you already have qt 7. Follow the instructions and you will be fine
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.3
    FCP 5.03
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
    January 5, 2006 at 10:43 pm
    THANK YOU VERY MUCH!!! It worked !!
  • Adam Weinberg
    February 22, 2006 at 4:48 am
    thanks so much, i really appreciate it
  • Michael Cocivera
    November 10, 2009 at 4:52 pm
    I am trying to capture in Final Cut 7 in a macbook pro with a Firewire 800 to Firewire mini 4 pin to my Canon XH-A1. I tried all the different HDV capture settings and this should not be a capture settings issue (or at least it should not be) I am in complete confidence that the deck is working fine because I tried it on an older IMac with the same software. The only difference was the cable I used. Is there a specific setting needed to use to capture footage with firewire 800 in the HDV1080i60 capture setting??
