Activity › Forums › Apple Final Cut Pro Legacy › FCP won’t open
  • FCP won’t open
    Posted by Jeff Hess on January 4, 2010 at 8:52 am
    I’m using FCP 5.0.4 on a G5 Dual 2.3 GHz
    When opening FCP (today) an error came on that my primary hard drive had gone off line. I hit ‘check again’ to no avail, then hit ‘reset scratch disk’ which listed my scratch disk as “macintosh HD – offline”. I hit “SET” for this drive and it then read “macintosh HD” (the ‘offline’ was dropped) making me think all was good but the FCP bootup continued a short way then aborted (no error). Now, everytime I try to open it drops off a short way into the bootup, still no error and now apparent way around.
    Anyone seen this before? Any advice appreciated.
    -jeff
    Jeff Hess replied 16 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Rafael Amador
    January 4, 2010 at 10:14 am
    The corruption of a single file may be causing the crash.
    Try to open the project with all the media off-line and reconnect by bunches, this way you may isolate the offending file.
    Rafael
    http://www.nagavideo.com
  • Jeff Hess
    January 4, 2010 at 10:36 am
    Thanks Rafael but I’m afraid it’s the application that is failing to load (doesn’t even reach the point of loading the project). Can’t open other projects either.
    -jeff
  • Rafael Amador
    January 4, 2010 at 11:37 am
    hi Jeff,
    Then try with DiskWarrior or another application to optimize your System.
    Just a wrong “File Finder Info” may be causing all the mess.
    Rafael
  • Roli Rivelino
    January 4, 2010 at 1:48 pm
    Try Rafael’s solution, before you try disk warrior go into your projects folder and double click on each and every project opening up one at a time to see if that works.
    Also your scratch should be separate from your boot up disk, if you don’t have another internal disk, get an external and make that your scratch, as this will avoid potential problems in the future.
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
  • Jeff Hess
    January 4, 2010 at 8:56 pm
    Hi Rafael,
    Booted with Disk Warrior and rebuilt drive to no avail. FCP still fails to bootup.
  • Jeff Hess
    January 4, 2010 at 8:58 pm
    Hi Roli,
    I’ve tried numerous projects (all with the same result) and have booted from disk warrior and rebuilt drive, still unable to get FCP to bootup. Is there any way to change the scratch disk without opening FCP? An editable cache file?…
  • David Roth weiss
    January 4, 2010 at 9:03 pm
    [Jeff Hess] ” Is there any way to change the scratch disk without opening FCP?”
    Trash preferences — that discards the stored link to your scratch disk.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jeff Hess
    January 4, 2010 at 9:24 pm
    Thanks David (and others for advice),
    Trashing preferences did fix this and I’m back up and running with scratch disk set to external drive.
    Cheers,
    Jeff
