Activity Forums Apple Final Cut Pro Legacy FCP won’t launch. Possible conflicts with Avid Xpress Pro 4.8.1?
  • FCP won’t launch. Possible conflicts with Avid Xpress Pro 4.8.1?
    Posted by Michaelhelenek on December 1, 2005 at 6:00 am
    I just purchased FCP Studio and a new dual 2.3 G5. Installation ran fine. All other apps open (ie: soundtrack, dvd studio, motion, compressor, etc.).
    When I try to open FCP 5.03, it starts to open – anotherwords the rectangular box with FCP and my name and the serial number comes up like it’s going to launch, but then the box goes away and no application. The finder then becomes active.
    I’m running on and OS 10.4.2 and QT 7.0.1 and would rather not go to 10.4.3 or a higher version of QT as I need this OS and QT for my Avid Xpress application. Plus I do not suspect that the OS or QT version is the problem, as we know FCP has launched on OS 10.4.2 and QT 7.0.1. All other software is up to date.
    Possibly there are software conflicts with Avid? The only other software I have installed on this machine is that which was packaged with Avid Xpress Pro v.4.8.1 which is as follows:
    Avid Xpress Pro v4.8.1 (which includes)
    Avid ALE
    Avid EDL Manager
    Avid FilmScribe
    Avid MetaSync Manager
    Avid MetaSync Publisher
    …and also:
    Boris FX 6.1 LTD
    Bors Graffitt 2.1 LTD
    ATTO ExpressStripe
    Factory Floor
    Sonic Fire Pro v.3
    Sorenson Squeeze
    Any insight on how to launch FCP would be very much appreciated. Thank you.
    Michael.
    Michael Helenek
    Video Editor
    Michaelhelenek replied 20 years, 5 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    December 1, 2005 at 5:48 pm
    Was the Boris FX software installed for FCP or Avid? might be the problem…
    Try trashing your FCP prefs and see if that helps.
    I’d not run an Avid system on the same system as FCP in any event… it’s holding you back softtware wise for one thing. i.e. you should be running 10.4.3 and QT 7.03 on FCP 5.0.3 for the best version of FCP 5 right now.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Michaelhelenek
    December 1, 2005 at 7:53 pm
    Jerry,
    Thank you. Boris was installed for Avid. Came with the Avid software.
    I need to stay current on both software set, hence both on the same system. Unless I opt for 2 comuters.
    Thank you,
    Michael.
    Michael Helenek
    Video Editor
