FCP won’t import .avi fiFile Error: 1 file(s) recognized, 0 access denied, 1 unknownle. “”
I’m trying to import 39 s of footage shot on an underwater camera, but get the error message: File Error: 1 file(s) recognized, 0 access denied, 1 unknown.
I can play the footage with programs such as Quicktime, VLC, Realtime, and MPEG Streamclip. With the latter, I’ve tried to export it to various formats but each time it hangs. It also hangs when I try to import it into Motion3.
This is what MPEG Streamclip returns for Stream Info:
Stream: M00-0063.AVI
Path: /Volumes/HAWKS/MOB/M00-0063.AVIDuration: 0:00:39
Data Size: 52.19 MB
Bit Rate: 11.09 MbpsVideo Tracks:
DivX 5.0, 640 × 480, ~25.004 fps, 10.87 MbpsAudio Tracks:
DVI IMA stereo, 32 kHz, 257 kbpsStream Files:
M00-0063.AVI (52.19 MB)The curious thing is the frame rate, and sure enough when I step through the video, occasional frames are missing or duplicated (all the frame content is different). e.g. (from the beginning) 00, 06, 08, 09, 09, 11, 12, 12, 14, 15, 15, 16, 18, 18, 19, 21, 21, 22, 23, 24, 00
Can any one suggest how I can fix this?
Richard Jordan
