Activity Forums Apple Final Cut Pro Legacy FCP won’t draw waveforms in the timeline!
  • FCP won’t draw waveforms in the timeline!
    Posted by Tim Young on May 7, 2010 at 9:25 am
    I’ve just been given a Mac Pro tower to edit on loaded with FCP 605. I’ve plugged my firewire drive in to it and it all looked ok to start with … but it won’t draw waveforms in the timeline, which is infuriating! Is there a cache file or something that I need to set?
    I was working on a MacBook Pro with FCP 606. That drew the waveforms fine.
    What should I check to get the tower to draw the waveforms?
    Tim
    Tim Young
    Tim Young replied 16 years ago 5 Members · 6 Replies
  • Adam Taylor
    May 7, 2010 at 10:14 am
    check your sequence settings – its an option in the timeline tab.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Tony Brittan
    May 7, 2010 at 12:24 pm
    Try: option>command>w with the timeline selected to enable them
    Tony Brittan
    Apple Certified Pro – FCP
    YouTube.com/tonybvideo
    islandshoreproductions.com
  • Tim Young
    May 7, 2010 at 1:27 pm
    Even when I match framed clips to the viewer on the tower, it wouldn’t draw the waveforms.
    I’m back on to my MacBook Pro, as the tower had a big crash and I don’t trust it!
    Must be something to do with not seeing the Waveform Cache Files folder, coz when I recorded VO on the tower the waveform appeared, but now when I open the sequence on the MacBook, all the original waveforms appear, but NOT the ones for the VO I recorded on the tower.
    Strange.
    Tim Young
  • Doug Beal
    May 7, 2010 at 3:05 pm
    delete waveform cache files. reset where they go in system settings. should force a redraw if not the usual trash prefs etc
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Dan Bannett
    May 8, 2010 at 1:50 am
    Try deleting your audio render files and turning off Auto Render in the user settings. I see this issue from time to time when working between two systems and one of systems has auto render turned on.
  • Tim Young
    May 8, 2010 at 8:49 am
    Thank you for all your posts.
    Will try and get the machine to behave on Monday!
    Tim
    Tim Young
