Activity Forums Apple Final Cut Pro Legacy FCP Won’t Capture HDV?
  • FCP Won’t Capture HDV?
    Posted by Ryan Zernec on May 7, 2010 at 11:54 am
    Hey guys,
    I have a project that was shot entirely in HDV, miniDV tape. I have tried and tried and I cannot get FCP to recognize either of the devices I’ve attempted to capture from. I have tried the camera itself (don’t remember which model, it was borrowed, but I will find out), and I’ve tried a Sony HVU-M15AU. The ONLY way FCP will capture from either device is with the Apple Intermediate Codec, which I’ve been told reduces quality. I can’t seem to capture straight HDV, no matter what I try.
    I’m working with a 15″ Macbook Pro, in FCP 5. I’ve tried turning off the downconvert option on the HVU, and the iLink, no help. I’ve tried every Easy Setup, and every other setting I can see. Nada. Can anyone help?
    I’ve been thinking about getting a FCP 7 upgrade, would this help??
    On a whim I tried capturing with Adobe Premiere, and everything went fine. Go figure.
    Tom Matthies replied 16 years, 3 months ago 5 Members · 6 Replies
  • Tony Brittan
    May 7, 2010 at 12:31 pm
    I believe FCP 5 only captures HDV as Apple Intermediate codec. FCP 6 & 7 will do straight HDV, but you don’t want HDV anyway. 6 & 7 allow you to capture as Apple Prores and that’s what you want. Don’t worry about HQ…regular Prores is perfect. Do a search on the workflow. You really need to upgrade. If and when you do, wipe your drive and start from scratch with a full fresh install.
    Hope that helps!
    Tony Brittan
    Apple Certified Pro – FCP
    islandshoreproductions.com
  • Ryan Zernec
    May 7, 2010 at 1:28 pm
    Thank you, that helps tremendously! I was hoping to avoiding spending money on the upgrade right now, but I suppose its time anyway. I will give it a shot, thank you!
  • Ted Ryan
    May 7, 2010 at 2:13 pm
    If you do end up getting FCP 6 or 7 – capture HDV-Apple Pro Res.
    However, definitely do NOT CAPTURE Apple Pro Res “HQ” unless you have a capture card.
    Pro Res HQ via FireWire crashes your system, gives you corrupt clips, and capturing hell.
  • Chris Borjis
    May 7, 2010 at 4:02 pm
    You can capture HDV with final cut pro 5. it was the first version that supported it.
  • Ryan Zernec
    May 7, 2010 at 6:54 pm
    I’m on FCP 5, and I can’t get it to recognize or capture from either device that I’ve tried. If there’s a trick to it I’d love to know, because I’ve tried everything I can think of.
  • Tom Matthies
    May 8, 2010 at 7:36 am
    Was that version 5 or 5.1 that worked with HDV?
    Tom
    Life moves pretty fast. If you don’t stop and look around once in a while, you could miss it.–Ferris Bueller
