Activity Forums Apple Final Cut Pro Legacy FCP without deck, just a DVD burner?
  • FCP without deck, just a DVD burner?
    Posted by Arthur Lunn on August 19, 2005 at 5:25 pm
    I’m going to get a panna 100A and FCP5 studio package and I was thinking, do I really need a deck? Why don’t I just capture from the camera directly and just burn a DVD master that I could send out to be replicated if possible? Skip having to throw in a DV deck in there somewhere?
    Drizzt_g replied 21 years, 1 month ago 4 Members · 3 Replies
  • Hector Candleleven
    August 19, 2005 at 5:53 pm
    What if the camera fails but you still have footage to capture?
    What if you need to log and capture tapes but you also need to get some B-roll footage on a short time schedule? Which do you do first when instead, someone is log and capturing tapes while you get your extra footage?
    One alternative is buying a very cheap DV camera from BestBuy and using that as a deck.
    One other potential problem is that you limit yourself to Mini DV’s. With a full size deck, you get the extra option of DVCAM or DVDCPro.
  • Bouncing Account needs new email address
    August 20, 2005 at 3:46 am
    I don’t think you should feel like you’re the only one with this idea.
    There must be thousands of FCP users who don’t own a deck and just use a DV camcorder for input and output back to tape.
    This is how the FCP system was originally designed.
    Its certainly EXACTLY how iMovie is designed to operate.
  • Drizzt_g
    August 23, 2005 at 4:07 am
    I’m with Hector on this one. And don’t forget that cameras are not really design to be use as a deck so the cost of repairs will increase. May be I’m wrong but I’ve always heard the heads of the camera are not good for this use.
