Activity Forums Apple Final Cut Pro Legacy FCP with XDCAM HD
  • FCP with XDCAM HD
    Posted by Oliver Parker on March 4, 2007 at 2:17 am
    I have been working with footage from the XDCAM HD for the past few months but so far have been unable to use the XDCAM HD 35mbps 25p sequence preset. I can only get the footage to work on a sequence using the HDV sequence preset. I have a big project coming up where i need to get the most out of the HD footage and want to make sure that FCP is set to its optimum. Any ideas?
    Oliver Parker replied 19 years, 6 months ago 4 Members · 5 Replies
  • Shane Ross
    March 4, 2007 at 4:11 am
    Which version of FCP? Because 35MB/s support was added with version 5.1.2.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Andy Mees
    March 4, 2007 at 6:35 am
    that would suggest you are only shooting in SP mode and consequently only the HDV preset will work.
    you need to shoot in HQ 25p if you want the XDCAM HD 35mbps 25p sequence preset to work.
  • Oliver Parker
    March 5, 2007 at 12:48 am
    i am running 5.1.2
  • Mark Maness
    March 5, 2007 at 3:29 pm
    Are you using the Sony Transfer Software v1.1?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Oliver Parker
    March 6, 2007 at 5:10 pm
    Problem solved. thanks
